Dec 7, 2016 at 10:05 am
Hello Syams,
Please ensure that you are using the latest version of the theme via FTP because this is the surest method in this regard. We do not make any changes in theme panel the Article Inline Ads should have this options there. If the problem is still there, please try to re-install the theme via FTP, clear all your caches and check again the results. For more information about this way, please consult here -> https://forum.tagdiv.com/newsmag-install-via-ftp/
Jan 14, 2017 at 6:11 am
The same problem here. I installed the theme again but still not working
Jan 14, 2017 at 6:21 am
It Worked 🙂
First, i deleted newspaper folder(Not child theme)
Then I upload it again.
