Author Missing Problem!!!
When i check the google webmaster, author missing problem bar keeps raising everyday. I’m tires of this problem, everybody writes something that “in the loop.php, in the single.php change the author vcard bla bla) there is nothing like that in those php files and i cant fix this problem. I have also breadcrumb problems. In the webmaster tools, breadcrumbs of the titles are missing too.
I love this theme, but has so many problems. But nobody helps me to fix it.
I’m waiting help, please.
my web site is: http://www.bilmiyorsan.com
I also checked your site and found no issues: http://screencast.com/t/A8ZHGiF03I
Please provide more details about the issue!
http://i59.tinypic.com/6izfgo.jpg
http://i58.tinypic.com/300az9l.jpg
http://i58.tinypic.com/v8dml4.jpg
http://i62.tinypic.com/1zvtvlh.jpg
if you can check these links, you can see what i am trying to explain.
Thanks for your answer.
Please make sure you update the theme to the latest version (1.5) as we have fixed this issues in latest theme version.
Use this guide and the ftp method and make sure you also make backup of you current theme installation: https://forum.tagdiv.com/how-to-update-theme/
