Hello
I just realized a php issue after we started having author pages issues. I’m not sure if this is a TAGDIV composer issue because the issue only cleared if TAGDIV composer disabled or WPML CMS disabled. For your information; WPML informed us this is not related to WPML- at least for the moment. I’ll go deeper into the issue once I hear your suggestions about it.
Author Main Languge
Author Secondary Language
So we string translated author details but, Main language don’t appear.
Contacted Yoast; reply here
When we ran a cURL test on the relevant author URL Author Main Languge, we see a 403 or 500 internal server error as the HTTP response results. We also don’t see anywhere that Yoast SEO causes this issue, nor it redirects to a different page at all.
Contacted Hosting; reply here
We are able to replicate the 403 error via cURL. We updated your files permissions and the issue persists.
When we rename your .htaccess file cURL shows a 404 error as shown below :
$ curl -sI Author Main Languge
HTTP/1.1 404 Not Found
Date: Tue, 18 Feb 2020 14:07:08 GMT
Connection: keep-alive
Set-Cookie: __cfduid=d1b130608b54ae7b56df6a8826823610d1582034828; expires=Thu, 19-Mar-20 14:07:08 GMT; path=/; domain=.XXX.COM; HttpOnly; SameSite=Lax
Strict-Transport-Security: max-age=63072000; includeSubDomains
X-Frame-Options: SAMEORIGIN
X-Content-Type-Options: nosniff
X-Turbo-Charged-By: LiteSpeed
CF-Cache-Status: DYNAMIC
Expect-CT: max-age=604800, report-uri=”https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct”
Server: cloudflare
CF-RAY: 567090cd2e05fe06-DTW
Contacted WPML; reply here
There’s fatal error on Uncaught Error: Call to a member function the_post() on null in /home/xxx/xxx.com/wp-includes/query.php:937
Image to the code; https://pasteboard.co/IVoIq5t.png
Besides; here’s the other debug logs about the theme
18-Feb-2020 13:22:54 UTC] PHP Fatal error: Uncaught Error: Call to a member function the_post() on null in /home/xxx/xxx.com/wp-includes/query.php:937
Stack trace:
#0 /home/xxx/xxx.com/wp-content/plugins/td-cloud-library/wp_templates/tdb_view_tag.php(17): the_post()
#1 /home/xxx/xxx.com/wp-includes/template-loader.php(98): include(‘/home/xx/…’)
#2 /home/xxx/xxx.com/wp-blog-header.php(19): require_once(‘/home/xxx/…’)
#3 /home/xxx/xxx.com/index.php(17): require(‘/home/xxx/…’)
#4 {main}
thrown in /home/xxx/xxx.com/wp-includes/query.php on line 937
[18-Feb-2020 13:55:56 UTC] PHP Warning: Use of undefined constant TDC_PATH_LEGACY – assumed ‘TDC_PATH_LEGACY’ (this will throw an Error in a future version of PHP) in /home/xxx/xxx.com/wp-content/plugins/td-composer/td-composer.php on line 109
[18-Feb-2020 13:55:56 UTC] PHP Warning: Use of undefined constant TDSP_THEME_PATH – assumed ‘TDSP_THEME_PATH’ (this will throw an Error in a future version of PHP) in /home/xxx/xxx.com/wp-content/plugins/td-composer/td-composer.php on line 113
[18-Feb-2020 13:56:14 UTC] PHP Warning: Use of undefined constant TDC_PATH_LEGACY – assumed ‘TDC_PATH_LEGACY’ (this will throw an Error in a future version of PHP) in /home/xxx/xxx.com/wp-content/plugins/td-composer/td-composer.php on line 109
[18-Feb-2020 13:56:14 UTC] PHP Warning: Use of undefined constant TDSP_THEME_PATH – assumed ‘TDSP_THEME_PATH’ (this will throw an Error in a future version of PHP) in /home/xxx/xxx.com/wp-content/plugins/td-composer/td-composer.php on line 113
[18-Feb-2020 13:56:15 UTC] PHP Warning: Use of undefined constant TDC_PATH_LEGACY – assumed ‘TDC_PATH_LEGACY’ (this will throw an Error in a future version of PHP) in /home/xxx/xxx.com/wp-content/plugins/td-composer/td-composer.php on line 109
[18-Feb-2020 13:56:15 UTC] PHP Warning: Use of undefined constant TDSP_THEME_PATH – assumed ‘TDSP_THEME_PATH’ (this will throw an Error in a future version of PHP) in /home/xxx/xxx.com/wp-content/plugins/td-composer/td-composer.php on line 113
[18-Feb-2020 13:56:51 UTC] PHP Fatal error: Uncaught Error: Call to a member function the_post() on null in /home/xxx/xxx.com/wp-includes/query.php:937
So, I’m looking forward to hear from you
This topic was modified 6 years by
fatih-2.
Please make sure that you do not have a plugin conflict with untested plugins, please deactivate all non theme/tested plugins, also if you are using child theme, clear all cache and try again.
The list of all tested plugins can be found in here: https://www.screencast.com/t/NNVYRGioUNs1
If there is still a problem, you can send us an email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will take a look. Include a link to this topic in the email.
Also another thing that you can do is to make sure that all the settings are like in our requirements, please follow the guide carefully
Let me know the results!
If the problem persists, you can make a full backup to your website and send us an email at contact@tagdiv.com and provide admin login, as well as cPanel. We will take a look. Include a link to this topic in the email.
