Auto Next Post Load sidebar can't follow scrolling?
I try Auto Next Post in my website yesterday and the sidebar bother me. There’s the same sidebar load in the next post. Can you guys any suggestion or tutorial about the single sidebar only floating pass through next and next and next post?
Do you are referring to the Sticky Sidebar? If you want to achieve that functionality, you need to enable the Sticky function from TD Composer and from the Theme panel -> https://www.screencast.com/t/31dgiyItKT2w -> https://www.screencast.com/t/cVS9K3TAw If is not what you mean, please provide more details and some useful screenshots so I will be able to provide a more accurate response.
I do enable sticky sidebar but the sidebar just stop before footer, and another sidebar appear to the next post (i use autoload next post) what I want to say is it possible we use single sidebar for autoload next post so the sidebar keep scrolling and not reappear with the next post?
The auto-load next post will load the next post and the sidebar that is set for it. There is currently an issue that is happening however, the sticky sidebar doesn’t seem to function correctly starting from the first auto loaded post. Meaning it will not be sticky anymore. This will be fixed. Sorry for the inconvenience.
Hi Simion C.
Was this issue ever fixed? This was over a year ago and it appears to still be happening.
Hello, @jasonpel,
I just replied in your own topic, please check https://forum.tagdiv.com/topic/sticky-sidebar-not-moving-with-auto-loading-posts/
