Avoid same post from appearing on home page
Is there a method to avoid same post appearing on my homepage.
This is my site http://www.musicforlondon.co.uk
Titus
If you use the same sorting for blocks and grids, there could be duplicates or even the same post displayed exactly. There are settings like filtering and sorting to try and avoid it
– https://forum.tagdiv.com/block-settings-guide/
In case the same sorting is necessary, there is an offset option you can use
– https://forum.tagdiv.com/offset-feature/
Or, as I see you don’t use pagination for the elements in the homepage, activate the unique articles setting
– https://forum.tagdiv.com/unique-articles/
Hi Simion,
Thank you for pointing it out, I would have never found it.
I used the 3rd option.
Works perfectly.
Titus
