I remember trying to add a block as a widget a while back, but not through a child theme
– https://forum.tagdiv.com/topic/registering-custom-widgets/
I don’t think it is possible from a child theme. Not all them files are supported to be used in a child theme.
If you use the tagDiv composer, now there are flex blocks which have a great deal of customization options, so maybe the result you achieved with the block you added can be achieved with a flex block.
With the cloud library you can design templates and create them entirely with the tagDiv composer, bypassing the need to use widgets
– https://forum.tagdiv.com/tagdiv-cloud-library-plugin/
– https://affiliate.tagdiv.com/#/load/All
Hi Simion,
Yes I want to use it from the theme child or plugins though.
Thanks to you I found this solution working within a plugin you have to put in your td-bespoke-plugin.php:
add_action('widgets_init', function() {
return register_widget(new td_block_widget( 'td_block_bespoke' ));
