Big grid full 9 and website not same on mobile
Thanks for your reply,
but with my three problems only one problem solved and that is how to delete the empty column in tagdivi composer [ solved ].
Now, look the big problem in my website [ http://www.akhourigen.com ] is that i have a video playlist in the homepage and also a separate page for the videos and these videos is not showing in mobile version. i have tried everything as you told me earlier but nothing worked for me. i have tried to switch off the mobile theme but not worked.
also in mobile version not a single grid is showing as a post only the latest post shows [ no grid is showing nor my video is showing in mobile version ]
Videos is very important for my website to show as on desktop version and also on mobile version, i want to show both as i uploaded a separate video form from the add media option of post or a video youtube playlist. i want that people see my website post and videos on every devices. [ want everything in mobile version with AMP too.]
So, tell me the step by step point that how to achieve that because your tutorial page not worked for me.
last problem is that the big grid full 9, i don’t have any background image still the grid is small, it’s not coming up with full width.
Make sure to provide the clear steps that how to do it.
thanks.
That is how the mobile theme works. The mobile version of pages will not be the same as the desktop version. This is explained in the guide – https://tagdiv.com/mobile-theme-automatic-optimization-for-mobile-newspaper-theme/
So while the desktop page can be built with the composer, and contain blocks, grids etc. the mobile version is limited to the mobile editor – http://prntscr.com/o8vbaq
If a page contains no content in the mobile editor, on phones it will be empty when the mobile theme is active.
The homepage on mobile displays a top grid with featured posts
– https://forum.tagdiv.com/featured-posts-2/
Then there will be a latest articles section. If you enter content in the mobile editor for the homepage, it will be displayed between those 2 sections.
If you want to see see how the mobile theme looks and works, please check this demo with a phone, it has the plugin active – https://demo.tagdiv.com/newspaper_local_news/
I should note that in coming updates there will be more options added for the mobile theme, like for example the option to disable it for specific pages and many others.
The plugin is optional, if you want the same content from desktop to be displayed on phones, you can disable the mobile theme plugin.
Please let us know if you have more questions.
