Big grid full 9 and website not same on mobile
I loved your newspaper theme and recently i have purchased the this theme and now i have almost completed my website building but there is a three problem in it:
1- The ” Big grid full 9 ” is not working as a full width grid on my homepage in fact not any big grid full option is working as a full width grid for a homepage on my website.
2- My website is not showing as same on mobile devices as it is showing on my desktop pc. also i don’t have any jetpack plugin so let me know the final step what to do.
3- In ” tagdiv composer ” tell me how to delete the empty column because i have used the option ” clear ” but nothing happened.
let me know that how to deal with these problems with a final point because my deadline is near.
Thank you for the kind words, we will try to help as much as possible.
1. There is an explanation for this. Is there a general background set in the theme panel?
https://forum.tagdiv.com/background-introduction/
If a background color or image is set in the theme panel, the website will be boxed, in order to display the background. Please check if that is the case. Removing the background will allow full width grids and other wider elements.
2. Maybe the mobile theme plugin is active – https://tagdiv.com/mobile-theme-automatic-optimization-for-mobile-newspaper-theme/
When the plugin is active, the mobile pages, posts, etc will be different from desktop. However this plugin is optional, if you want the same content from desktop on mobile you can disable it.
I should mention that in coming updates there will be an option to choose for which pages or posts you want the mobile theme to be active.
3. Using the clear option on a row will only remove it’s content. If you want to remove a row you can click and drag it to the right corner – https://www.screencast.com/t/LocGydRWO
or click on it and hit the delete key on the keyboard.
If you have more questions let me know.
