Big Grids and Blocks after comments section
Is it possible to add widgets such as the blocks and the big grids after the article post. Like after the comments and I will title the grid “also check out these”
Yes, you can with single templates from the new Cloud Library Plugin https://forum.tagdiv.com/tagdiv-cloud-library-plugin/.
