Big problem with Theme panel
Dear Tag Div,
I have big problem with Theme panel and other menus connected with you theme. I was updating theme and in final I cant use my system fully because it makes this … look on the pictures. I have no problem to instalation theme again but I dont want to reinstall whole site. If you can help me it will be nice.
Here are pictures:
http://www.xczechmodels.com/1.jpg
http://www.xczechmodels.com/2.jpg
http://www.xczechmodels.com/3.jpg
  • This topic was modified 10 years by xczech.
Alternative links
http://xczech.tumblr.com/post/138726422553
  • This reply was modified 10 years by xczech.
Please try to disable all plugins except visual composer, clear cache and reset cdn if you use it to rule out a plugin conflict.
If the problem is not solved afterwards, please try to download the theme again and install it via ftp. (You can delete the current theme as your settings will not get affected but just to be safe you can make a back-up beforehand) https://forum.tagdiv.com/install-via-ftp/
Let us know how it goes.
