Hello there,
First I created a Blank – Single Template with TD Composer—-there is the link: https://daddynovela.com/lucian-hawkthorn/?td_preview_template_id=242
Then I create a post; here is the link: https://daddynovela.com/lycaonx-wolfsbane/ with that Blank – Single Template and edited for my requirement with TD Composer. And It’s all okay. It’s showing/ Display fine.
But When I create a one more post; here is the link: https://daddynovela.com/lucian-hawkthorn/ with that Blank – Single Template and edited it with TD Composer for another post, it’s now showing wrong, My two post got the same, I mean the two post display same results. I hope you get me. Now, please help me fix this.
Hello @daddynovela!
You should use the single elements that takes the content from Gutenberg and also the featured image automatically. For example: Page Title, Single Post Featured Image, Single Post Content. Documentation here: https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
