Blending Membership (subscriptions) with Products in Store
Hi there.
I am attempting to add a digital flipbook to my woocommerce store in addition to my offline print magazine. I have tried a few different things after speaking with woocommerce reps to no avail. They are wanting me to purchase their membership plugin, but it has not been tested with tagdiv, and I’ve had nothing but trouble in that department.
I’ve read through your Opt-in Builder plugin, but I have a few questions regarding this. If you look at my website livelovelocalmi.com/subscribe-5, you will see the store products for my printed versions.
I have an annual subscription and also individual issues for purchase (just launched this month). I need to do the same for my interactive digital flipbook.
I have an embed code for my digital flipbook from the company that I’m using to produce it that has built in security baked in so that it can only be viewed on my website.
The issue that I’m running into is that I seem to only be able to embed the magazine to my current store setup where it is fully viewable within the product description BEFORE purchase and does not show up under their account information. I need it to be accessible ONLY after purchase under their account information ongoing after purchase, and have the ability to add my monthly digital flipbooks to their account if they purchase an annual subscription.
If I use the Opt-in Builder for membership, am I able to:
1) Have the membership options under my current store so all of my products are under the same store page?
2) Am I able to create membership products that are only visible after purchase and are located (embedded) under their account information for access anytime after purchase?
3) Will adding the Opt in Builder cause any issues to the formatting of my site as it currently sits? I’ve had a lot of issues with plugins breaking things making the site a challenge to operate.
Thanks for your guidance on this. Woocommerce is not able to provide me with any viable solutions.
1-2. Unfortunately, the Opt-in builder is not fully integrated with Woocommerce.
3. No, it won’t break the design because we have a common style of templates, the cloud templates.
I’m following up on this because I’ve not been able to find an alternative solution and woocommerce cannot give me what I need with a guarantee that it will work with tagdiv.
1. If I do membership for my site through Opt-in builder, I need to know that I can add content that is only viewable to those who have subscribed. This is a magazine, so I would need it to run like any other media where there are free articles, but they have to purchase a subscription in order to read others. This is unlimited with opt-in builder, yes?
2. To clarify, you do not integrate with woocommerce but I do need to keep my woocommerce store live for other products that are not membership based. How does this integrate with my current account login and account page? Does opt-in builder membership page get integrated to my current account page or are my subscribers going to have two separate account pages?
3. Where do I find the opt-in builder plugin?
1. Yes, this can be done using the Opt-in builder, if you want you can check some or our demos to see how it’s work – https://i.imgur.com/vaQOZb0.jpg -https://demo.tagdiv.com/select_demo/newspaper-prebuilt-websites/
Also, you can check the documentation of tagDiv Opt-in builder to see how it can be set – https://forum.tagdiv.com/tagdiv-opt-in-builder/ – https://i.imgur.com/wPiKQsd.png
2. Normally the opt-builder subscription is based on subscriptions made using this plugin, so if the subscription was made using the woocomerce it will not work, but those will have access to the shop pas on the current account.
3. The opt-in builder plugin can be installed from Newspaper > plugins – https://i.imgur.com/yQre6j5.png
