Block module problems
My website: https://inspiraonline.uk/
If you visit the homepage and scroll down, you will see a section called “Development Posts”.
I am using Block 5 module for that section, but the issue is even if I set the post count to 3, the section is displaying the post thumbnails vertically when it should be showing them horizontally as your demo does.
Example: https://demo.tagdiv.com/newspaper/block-header-3/ (MOST POPULAR section at the bottom, just above footer)
I can send a few screenshots if you wish.
Please make sure you are setting the block in Visual composer like this – https://www.screencast.com/t/ivfgTpSQC on a full row. Then you should have a result like here – https://www.screencast.com/t/UL6kmfv9ps
Hi Simion,
I have done this and the result is still the same – row is showing vertical nstead of horizontal.
Everything is working properly on my end, and if you are using the respective block on a full row it should display as intended as well. Maybe you have set custom class to that row, or you have some custom code affecting this. Also you should try as a test to disable all your plugins except Visual composer, clear any caching installed then create a new test page and add this block on a full row, to see if it displays as it is meant to. Please let us know how it goes.
Hi there, it is fixed now. But even after installing the latest version of the theme why the WPBakery Visual Composer plugin which comes with the theme asking for update ?
Can you please send me the latest one and also why it asks for activating license key ? Is it the same as the theme purchase key ?
Regadrs
The Visual composer plugin is provided in the theme package, and updated along with the theme updates. There is no need to enter a license code, it is provided pre-activated. The activation messages can be ignored because it does not prevent you from using this editors features. When a new update for Visual composer is available, it will be available as soon as possible in a theme update.
You can find more information about this here
– https://forum.tagdiv.com/how-to-update-visual-composer-plugin/
