Block order on mobile for 1/4+1/2+1/4
On desktop, the top home page block order using 1/4+1/2+1/4 looks great – but on mobile, I need the 1/2 to appear 1st, the 1st 1/4 to appear next, and then the last 1/4.
How can I accomplish this layout for mobile ONLY?
In that case you could create another row with the layout and elements you want for mobile below the current one. Hide the first row on mobile
– https://www.screencast.com/t/jhYG4hXBe
– https://www.screencast.com/t/YezxNK1E
And the other one on desktop – https://www.screencast.com/t/K6JWWp9qC7W
This means that you can display different rows desktop vs mobile. It could be a solution if you want to give it a try.
Perfect, thanks!
Hi! Yep, the layout per device worked great, BUT I need the content to duplicate itself – meaning, the mobile row should show the latest content just like the desktop row above it. Right now, the mobile row starts about 6 posts after the desktop row. Is there any way to have the “Latest” posts in 2 different rows?
If you use the same filtering and sorting for the blocks they all will display the same content. An exception is if you use the offset option per element or the unique articles page option
– https://forum.tagdiv.com/offset-feature/
– https://forum.tagdiv.com/unique-articles/
