I am encountering two issues.
1. In both the page builder or the tinymce when I try to make a custom block title (custom_title=) with accents or UNICODE it breaks and will not display the title properly.
2. It is a French/English site and all the previous/next article suggestions are coming up as the opposite language of the main article. How do I fix this?
Hello Digital chaos,
1)you should provide some useful screenshots with the error because I do not exactly understand the problem. Ensure that you are using the latest version of the theme.
2)Sorry but I do not know what kind of plugin you are using for language. Notice that we recommend the WPML plugin for this.
1) Sorry for the lack of info, I’ve since solved this.
2) We are using WPML and the latest theme and wordpress versions.
You should check the WPML documentation in order to achieve good theme results. -> https://wpml.org/documentation/ -> https://forum.tagdiv.com/using-theme-translations-together-wpml/
