Hi there
I’m using WP bakery to design my site, but after the latest update, Blocks and Grids do not show up in the “add Element” window. Which makes it really hard to create anything 🙂
(I have the same setup on another website, and here there are no problems)
Best
Bo
Hello Bo,
Please use our page builder, tagDiv Composer, where you can find more blocks which offer you more flexibility, please check these articles:
-> https://forum.tagdiv.com/flex-block-settings-guide/
-> https://forum.tagdiv.com/big-grid-flex-settings/
Also, now is a conflict between tagDiv Composer/tagDiv Cloud Template and WP Bakery which is why I recommend you to shift from WPBakery to tagDiv Composer because WPBakery is an old builder plugin => https://i.imgur.com/O4CA0y0.png -> https://i.imgur.com/bFnzNtQ.png -> https://i.imgur.com/mv8AhFU.png -> https://i.imgur.com/IMyLYiY.png
