Blocks / Demos not appearing as they Should
I’m trying to build a custom homepage and I’m adding Blocks and they arent appearing as they should…
For example I’m trying to use “Big Grid 1” http://screencast.com/t/3H2gJUs5x and only 3 of the articles show, when 5 of them are supposed to show. If I click the arrow to move over, another 3 show…
(Yes I have more than 3 Articles)
I may have edited blocks in the theme (I was messing around) is there a way to restore all the default block settings etc without completely screwing up what I’ve already done to my website?
Another thing thats going wrong is that if I try and do a “2 Column Block” like the block indicates it is… it only does 1 column.. I’ve tried switching the options to 3 columns etc and it still only shows 1.
Hello Noomadics,
Please ensure that you are using the latest version of the theme (Newspaper 7.1.1) and also, the latest version of the required plugins (Visual Composer 4.11.2 and Social Counter 4.0). Please ensure that this process was made only through FTP because this is the surest method in for updating. It is important to check this because it is possible that you version of the theme to be incomplete and that’s why not working as properly. Also, after this, please try to clear all your caches and test it again.
If you problem is still there, please try to make a new install from scratch with the latest version of the theme and check the results
Where do I update the Visual Composer and Social Counter?
Hello Noomadics,
Please notice that these types of plugins come bundled with our theme and for better results you will have to use the latest version of them (Visual Composer 4.11.2 and Social Counter 4.0)First of all, you will have to disable/delete all of them and then you will have to install them from Plugin area, like this -> http://screencast.com/t/SE7OlnfPuok For more information about how you can update your Visual Composer, please check here -> https://forum.tagdiv.com/how-to-update-visual-composer-plugin/ After updating, try to clear all your caches and check the results.
