Blog Filter Problem
Hello;
I have a problem with block in a page.
I have categories and I want a block for certain categories, But I couldn’t manage that.
Please help me about block category filter and also ajax filters also.
best Regards
Erhan
Hello alierhan,
If you need to filter your block by a certain category you have to use category ID and set this from Block Settings, like this -> http://screencast.com/t/LJksC1klJ or if you have more than one category, you have to use the category ID and add them in Multiple Categories Field from block settings, like this -> http://screencast.com/t/UB8Mte2Zp If you need to get the category ID, please check the steps here -> http://screencast.com/t/qrSBN5Ls4x For more information about these settings, please check our documentation here -> https://forum.tagdiv.com/block-settings-tutorial/
Hope this helps!
If is not what you mean, please provide more details about what you want to achieve so I will be able to provide a more accurate response.
Hey, Thanks for the reply.
Finding category ID was painful. But Thanks for the help, otherwise it will be impossible for me.
Erhan
Apple Haber
Hello alierhan,
Please notice that this is the only way to order your posts if you have more than one category ->> using category ID as I explained you above.
Hope this helps!
If you need more assistance and help, please let us know.
Thank you for the message!
