Everything was working fine and the breadcrumbs showed normal like on this link here:
https://cophumor.com/bad-start-to-the-morning/
I don’t know what changed but now, every new post I make has no title, and no breadcrumbs at the top. example here:
https://cophumor.com/ops-in-ukraine/
The ‘Post Template’ remains the same which is ‘from panel’. The Theme Panel settings seem to all be the same I don’t remember changing anything. I deactivated all my wordpress plugins and the issue is still happening.
Any help would be greatly appreciated, thank you!
Please edit this post https://cophumor.com/ops-in-ukraine/ with the TagDiv Composer and make sure you have the title and other elements in the template.
Let me know the results!
Hello, thank you for the reply!
When I go to https://cophumor.com/ops-in-ukraine/ I see no breadcrumbs and no title. Once I edit the post with the TagDiv Composer I can see the title, and the breadcrumbs showing up. Once I close out the TagDiv Composer the title and breadcrumbs disappear again.
Hi Cop Humor,
Do you have a featured image set for the post? Because the single post template that you have is configurate to display the post title and breadcrumbs over the featured image and if that one is not set, then the row holding all those elements is hidden.
Also, what you can do is to edit the single post template (Drag the elements from the featured image) or replace the singe post template with another one.
