Breadcrumbs issues
we are facing some troubles with the breadcrumbs where the pages are made with Visual Composer.
In the theme panel every option regarding breadcrumbs is enabled so I don’t know why isn’t working properly.
Can you please help us?
Thank you
It seems google changed their algorithm regarding breadcrumbs and for some users the breadcrumbs seem to show up differently than before. We are still investigating the matter.
Sorry, my explanation wasn’t clear.
I’m talking about breadcrumbs in our website page not in the google results page.
This image shows a simple standard wordpress page, no Visual Composer. Indeed there are breadcrumbs.
PAGE WITH BREADCRUMBS
The image below otherwise shows a page made with visual composer and no breadcrumbs.
Page with no breadcrumbs
We need breadcrumbs in page, so what we need to do.
In the theme panel every option for breadcrumbs is turned on.
Yesterday we provide you user information for our website, can you check it? Thank you
First image –> http://imgur.com/a/0etAV
Second image –> http://imgur.com/a/futX1
This depends on the page template you use. If you use the default page template the title and breadcrumbs will be removed when using visual composer. Please switch to the page builder + page title to show the title and breadcrumbs on your pages: https://forum.tagdiv.com/page-templates-2/
