I really like being able to use a custom taxonomy for breadcrumbs on a CPT, is there a way to also do this for regular posts?
Is there a hook I can catch onto to override the default breadcrumbs for that post if there is no built-in way to do it?
I’m sorry I did not understand what you are looking to edit.
A guide for CPT you can find here: https://forum.tagdiv.com/custom-post-type-support/
Hey,
Theme Panel -> CPT & Taxonomy -> Post Type -> Breadcrumbs Taxonomy
This setting lets me change the taxonomy for a custom post type. I like this and want to also change the breadcrumb taxonomy for the standard post type
If I understood correctly, then a possible solution could be this one: https://forum.tagdiv.com/primary-category/
Hope that helps you!
