Bug : Posts Loop : Offset
I am trying to stylize my page using breakups in the post loop for category pages.
When I set a second “Posts Loop” with an offset it does not work as expected on the front end.
In the tagDiv Composer it shows correctly but on the frontend it repeats the posts ignoring the offset.
Hello @vistaradio,
So I understood you add two blocks of the posts loop in your template, right? if yes, we do not recommend setting two posts loop on the same page/template, please use a flex block or another block, because most of the settings from the first loop element will be set for the second one.
OK, makes sense – however, the Flex blocks do not work well with sub-category pages as you need to specify what category they pull from.
I am trying to build a single category template that also handles the category pages without having to build unique templates per sub category. Mi idea was to break them apart for content break ups, but giving the continued content roll.
Sounds like, best way would be a per sub-category page template?
Please provide more details to be able to do a local test.
please send me a video of the steps taken.
