Build a theme for smartphone review site
here is the example need themes like this https://www.gsmarena.com/honor_magic7_lite-13581.php
Check these examples:
– https://demo.tagdiv.com/newspaper_shop_audio/
– https://demo.tagdiv.com/newspaper_shop_watches_store/
– https://demo.tagdiv.com/newspaper_pc_forge_pro/
You can use any demo from our list and apply the features:
– https://forum.tagdiv.com/reviews-7/
– https://forum.tagdiv.com/user-reviews/
Also, you can have a mix of them. You can import only some sections or templates of your current-designed pages from those demos. The template’s manager is in Cloud Templates.
Check out this video about how to create a website from scratch: https://www.youtube.com/watch?v=SoGQ0d5kIBg
I hope that helps you!
