Please check our documentation for header builder -> https://tagdiv.com/header-main-menu-newspaper-theme/
Please provide some more details about what you want to achieve and also please tell me the header that you want to have set, and I will try to help you to achieve what you want to achieve.
Thanks. I would basically like my menu exactly as it is now but with a large central logo like the one on the classic blog. Right now the one I am using has the log at the left and an ad spot on the right.
I have tried as many settings as possible but can’t seem to find that one.
Many thanks
Please make sure that the size of logo image is set to full size -> https://www.screencast.com/t/P8gvWIMUM set it on a full row and set it on center -> https://www.screencast.com/t/SAzoefq5Ck4n
If this is what you want to achieve -> https://www.screencast.com/t/RuWAmUADpyr, please make sure that you do not have set any header ads -> https://www.screencast.com/t/fIhUn9WsT and add this custom css in Newspaper?>Theme panel>Custom code>Custom css -> https://www.screencast.com/t/BYIaaIARL
.td-header-style-3 .td-header-sp-logo {
position: unset;
-> https://www.screencast.com/t/mWMy04BtUiX7
Unfortunately using header style 3 you can not achieve a bigger logo, for this you’ll need to use an header stile with full logo or import/edit one from tagDiv Cloud Library
