Categories and Posts Issue
I had installed the NewsPaper TodayNews Pro Theme and for some reason, the posts that should be in certain categories are not where they suppose to be on the homepage. I thought that it was my mistake and I deleted and reinstall the theme again where I needed to delete all the posts I was working on and took me a lot of time but it shows that the problem is from the theme itself.
For example: In the default homepage have Catagories for Entertainment, Celebs, Fashion, Travel, etc but under each category down the page, the post is only related to one category and not to the others.
Please Help!
Those are just titles, and you can edit them with tagdiv Composer, and set your categories titles after you can apply a filter for each block, with what category you want to display -> https://i.imgur.com/Ap2LH3b.png
Also, on our channel https://www.youtube.com/channel/UCOT1RiNysIPCTPSnVZskwtQ, you can find more videos that can help you and documentation https://forum.tagdiv.com/newspaper-theme-documentation/ and you can ask us here on the forum if you have any questions.
Thank you so much! it worked 🙂
You have to choose a category and use Filter.
