Categories going under block title (Block 15)
The categories are going under the block title when I first load the page up, once I start to alter the width of the browser it works fine.
Example
As shown the word ‘All’ appears under the title”
How can I fix this?
Adam
Please provide your website URL so I can take a closer look at it.
Hi Catalin,
It’s https://abtnews.co.uk/
Adam
Please provide the exact link where the problem appears because I do not see it.
Hi Catlin,
I’m pretty sure it’s a problem only when viewed in admin mode ( on every PC iv checked it works so fine so isn’t an issue).
However is there an option to change a number of categories displayed before the drop-down ‘more’ is at the end? Aka if I only wanted it to show 4 categories then the more button.
Adam
The ajax filter tab can be filtered by entering the Id’s of specific categories that you want to display
– https://www.screencast.com/t/nMIxktm6YdG
Here you can find all the available block settings and options
– https://forum.tagdiv.com/block-settings-tutorial/
