Categories problem
Why Categories on menu do not slide for more option, and why the categories when clicked points towards sample page ?
I am not able to get preview images on my home page as well as other related article columns, I can see images only on actual posts.
Got the slide option(without image preview) but still the category is pointing towards sample page, The category page is only visible at mydomain.com/category/health instead of mydomain.com/health
How do i stop pages like About us, privacy, contact from appearing on home page predefined blocks or other article blocks ?
1. Please check the documentation about how to make a category megamenu – https://forum.tagdiv.com/mega-menu/
If you done this properly and you still have issues, please disable all your plugins except Visual Composer, clear cache and check again.
2. Some plugins may conflict with the theme lazy load effect, so you could try to disable this feature – http://screencast.com/t/x2yxTw1cbj or check this without plugins.
3. Not exactly sure what you mean the url for category page must be mydomain.com/category/health
4 .Please check the documentation regarding the block settings, how to filter by specific category – https://forum.tagdiv.com/block-settings-tutorial/ and provide a link so I can inspect this and provide a solution.
Also this guide how to create and set a homepage – https://forum.tagdiv.com/homepage-how-to-build-and-set-it/ and you can check our youtube channel for some video tutorials – https://www.youtube.com/watch?v=rgWqozuqmJk
Other things are under control, but image preview is still the problem, no images in the home page, blocks or dropdown menu, BTW can i make a dropdown menu of only texts naming sub categories as in other websites
For the image preview on the main page you need to disable all your plugins except visual composer and check to see if the images show. If not, please provide a link to your website so we can take a look.
You can create a sub-menu in appearance->Menus like so: http://screencast.com/t/pzdvVHzAQM – https://www.youtube.com/watch?v=bxphw24ZvHY
