That is because you are using a predefined standard footer style, these can not be edit only to add new elements, if you want to set/change the footer elements choose an empty footer and set in Appearance>>Widgets>>Footer1/Footer2/Footer3 the elements you want to display. Also the text from about section can be set here -> https://i.imgur.com/9sdRpwW.png -> https://forum.tagdiv.com/newsmag-footer-templates-2/
An alternative is to use a cloud footer and you can edit it using the tagDiv Composer.
