child theme problem
Hi ,
After upgrade Newspaper to 8.5,child theme not work anymore.I’m using the child_theme from the package.
That would depend on the customization or modifications made through the child theme. Elements from the theme can change after updates, so the code you use might need to be adapted to work with the updated theme.
Try going over the modifications in the child theme, identify what is not working anymore and modify it if needed.
Thanks for reply.
I delete all the modifications.just the clean child theme files.still not working.I have updated to the latest 8.5.1
please check the images below.
cpt setting
MULTI - PURPOSE
Yes, after further investigations there was an issue with the mobile theme and child theme functionality in version 8.5. However these issues were quickly fixed in theme version 8.5.1.
Please reinstall the theme using the latest version, by FTP is usually the most recommended method to update
– https://forum.tagdiv.com/how-to-update-the-theme-2/
Then make sure that the tagDiv composer and multi-purpose plugins are active.
Also check the theme system status section section, ask your hosting provider to make modifications if needed
Everything should work properly. Let us know if you still have problems.
