I have the Default pro template on and I tried to change the color of an element button, but the palette color has not displayed; a box appeared instead as you can see in this screenshot https://photos.google.com/photo/AF1QipMfyft58z1WfchUpBEKVTtxnnDQS2CaEma6Jh_N
Even if I put the Hex code inside nothing happens no matter the browser I use ( tested on Brave, Chrome, Firefox, and Safari). My OS is macOS BigSur.
Still, another styling like to change border doesn’t work.
Hope you may help me
Sorry, probably the previous link image doesn’t work try this https://photos.app.goo.gl/RBqRhEpwLWbNtDrF7
This problem appears when you use the last WordPress 5.6 version with an old theme version.
My suggestion is to make sure that you are using the last theme version Newspaper 10.3.9.1 and check to see if the problem persists.
Before to update, make a full backup to all files and the database, in case something goes wrong. => https://forum.tagdiv.com/how-to-update-the-theme-2/
Let us know the results.
Another solution (for the moment) is to try a jQuery like, Enable jQuery Migrate Helper plugin and try this option => https://www.screencast.com/t/WYlKJVLi. Clear all the caches (also the browser cache).
Hope this can help you!
Let me know the results!
Anamaria,
still not working.
This was I had on Jquery plugin
https://photos.app.goo.gl/R1zZ4dHckHc6d7US7
Because the problem has not been solved, please make a full backup and send us an email at contact@tagdiv.com and provide:
– admin url and credentials
– A link to this topic in order to identify you.
Our team will take a look and will answer you as soon as possible.
You will have to first start looking for a plugin conflict.
Please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
We don’t know what can cause the problem, in order to help you, we need to log in as admin user(you can change the password after).
Thank you for understanding!
I found this, don’t know if it helps https://really-simple-ssl.com/knowledge-base/known-plugin-compatibility-issues/
well, things sound a bit more complicated. Deactivate Really SSl plugin and installed two different SSL plugins, but the problem persists.
Then even if I have all the plugins deactivate so that the styling is possible, still unable to delete the empty space row.
You’d better have a look and I’m going to send you my login credentials.
How long does it take? considering your days off, because I’m not comfortable having my 2 FA login off for long.
