Hello, when i try to edit “Column text” Element, it open window for edit content, but not load content.
As you can see in image there is a load spinner icon but any content. I can’t make any changes on existing element and same thing when i insert new “Column text” element.
Can you help me to fix?
https://www.screencast.com/t/IChLHg0t
Hello !
Please make sure that you have accomplished all the system requirements as in our documentation here: https://forum.tagdiv.com/requirements-for-newspaper/
Hello !
check attachments for errors… error in console say that there are some js issue into td composer plugin folder.
Hello !
– admin url and credentials
– cPanel url and credentials
Our team will take a look !
