Comment enabled on a post but comment area not showing for readers to comment
I have enabled comment on this post: https://www.netsportworld.com/football-predictions/predictions/
But the comment area is still not displaying for readers to comment.
https://imgur.com/QSxj0f6
How do I resolve this
This happens because you have in settings > discussion check the box for automatically closed comments after a set numbers of days -> https://www.screencast.com/t/96CzDYJIrl please uncheck the box and save the settings, after that clear all cache and see if there is still a problem ( the “Comments are closed” text should disappear and comments will open again ).
I have made the changes you suggested above but the comment box is still not showing
Hello @dessy1991!
First, you need to look for a plugin conflict. Please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Also, check these links documentation: https://forum.tagdiv.com/enabledisable-comments/ ; https://wordpress.com/support/comments/
Hope that helps you!
