Hi Team could you please suggest to me how can I disable comments on my website post
I had disabled from setting in the discussion section, but it is still coming
[newspaper theme]
thank you
Naushad
Hello Naushad!
Check this guide from here: https://forum.tagdiv.com/enabledisable-comments/
If you use a cloud/PRO template, then edit the single post template with tagDiv Composer and delete the Single Post Comment element from tagDiv Composer.
Hope that helps you!
