Comment section home page
I want to remove the comment section on the home page before the footer section
Regards
For the comments on homepage please disable this option from Theme Panel -> Template Settings -> Page Template => https://www.screencast.com/t/izMZkco5
This option is already disabled by default, but the comment section still appears on the landing page. I want to remove that comment section on the home page.
Hello @fpkakou!
If you use a cloud/pro template, then you can edit it with the TagDiv Composer and delete the comments section.
I still have the problem the comment section on the lending page is still there. Please help
Hello @fpkakou!
Please check this guide: https://forum.tagdiv.com/enabledisable-comments/
