Hi there,
I have enabled the comments (in Theme Panel > Post Settings and in the WP Settings > Discussion) but are not shown.
I use the default post template style 2.
Check the site at CodePeople
Looking forward to your kind advice.
Regards,
Andreas
Looking forward to hearing
Please make sure that you do not have a plugin that limit the comments or provide some conflicts.
Also make sure that you checm our documentation from here -> https://forum.tagdiv.com/enabledisable-comments/ -> https://en.support.wordpress.com/enable-disable-comments-for-future-posts/
Hi Calin,
I have no plugins that interfere with that. I’ve checked them all.
Also, the Theme settings and WP settings are exactly set as the guides in the link you mentioned.
Additionally, the comment section is shown and working on the Mobile Theme of my website.
Something else is causing the comment section to be hidden which I can’t find.
Regards,
Andreas
Please send us an email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will take a look. Include a link to this topic in the email.
What do you mean make a note of the email?
The email I’m talking with is the contact@tagdiv.com.
Could you kindly clarify that?
