I have this issue in “Newspaper system status”:
Speed Booster v4.9.1 – Disabled – incompatible plugin detected: admin-renamer-extended/admin_renamer.php
The plugin:
Admin renamer extended
Disattiva
Lets you rename all admin usernames with GUI.
Versione 3.2
The speedbooster plugin has an inbuilt plugin checklist, if it detects plugins outside that list it will deactivate itself. This is supposed to happen, as the speedbooster plugin could cause some plugins to not function properly.
The checklist could be disabled by modifying the plugin code
– https://forum.tagdiv.com/topic/tinymce-advanced-and-other-various-disabling-speed-boster/
Then check if everything works properly.
