I created the page https://www.gladbecker-zeitung.de but firefox shows the page is not save. i can not find the fault.
In the “theme panel”-settings at “background”, “mobile menu/search settings”, “background image” there is file “http://gladbecker-zeitung.de/wp-content/uploads/2020/09/login-mod.jpg” i can not delate. i habe the same proble at “sign in/join background”. There is a file “http://gladbecker-zeitung.de/wp-content/uploads/2020/09/login-mod.jpg” i can not delate. Are the two problems related? How can I delete the files?
Hello !
Please make sure that you have accomplished all the system requirements as in our documentation here: https://forum.tagdiv.com/requirements-for-newspaper/
Also, please check your console and if any errors appear, take a screenshot and send it to us so we can take a better look.
