Hello, we have installed the default theme and it is coming up with the following errors on the console:
Uncaught TypeError: Cannot read property 'src' of undefined
and also
Uncaught ReferenceError: u is not defined
These errors appear on posts. However, normal pages don’t seem to have the same issues
I’ve tried uninstalling the theme and plugins. I’ve also tried resetting the entire website to its default and it’s still coming up with the same errors.
Example at: https://staging10.motoreview.com.au/2021/02/18/eminem-stronger-than-i-was/
Hello !
Please send us a screenshot of your System Status Tab and make sure that all the requirements are met as you can see here: https://forum.tagdiv.com/requirements-for-newspaper/ ; You will have to first start looking for a plugin conflict. please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Also you can try and remove and re-install the tagDiv Composer plugin and please send us a link to your website in order to take a look.
Let us know the results.
