Content block not randomising posts
Hi, we have set the Left hand content block on this page – https://firstcardev.wpengine.com/buying/ to sort posts ‘random posts’, however this isn’t working and it’s mirroring the content block at the top of the page, which is set to ‘most popular’. We have plenty of posts in that category and other pages seem to work fine.
Please edit this page with TagDiv Composer and check if you set up “Random posts” and also check if you have offset field empty in that element.
Hi Bettina,
Offset post is empty and posts are set to Random Posts. It doesn’t matter what we switch the sorting to ‘Latest’, ‘Most popular’ etc, it doesn’t change the content at all, it’s almost as if it’s locked in some way?!
1. disable TagDiv Composer
4. install TagDiv Composer
5. activate TagDiv Composer
Also, make sure your WordPress and plugins are up to date(specially Standard Pack installed and active if you use default templates).
Sometimes, the issue can be from a plugin conflict, that’s why, please deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache(also from your browser) and try again.
We recommend using WP Super Cache plugin https://forum.tagdiv.com/cache-plugin-install-and-configure/
Let us know about your results!
Hi Bettina,
We’re a little concerned doing this so close to launch of our new site (Tomorrow AM). If I change the category to another we’ve created then the posts randomise, it’s just this one category we have that seems broken. Would there be any settings in the category that might impact this? We have 7 categories and 6 are fine. I can add a content block for the others and it behaves as expected when changing the filter options, but if I select ‘Buying’ it doesn’t work at all (just always shows the latest I believe).
Richard
Please give it a try with all steps mentioned above, and if it is not working, then please send an email at contact@tagdiv.com and provide wp-admin, so we can investigate this issue. Also paste a link to this topic so we can easily identify you.
