Couple Problems after updating
1. Having some problems with visual composer. When I try to edit a page the button does not appear for visual composer. I updated the theme, also after updating and deleted the plugin and reinstalled it to see if it was working and still no luck. I attached a picture of whats appearing.
2. Facebook Likes is still not showing after the update as well
3. Sometimes my website loads in a weird way and everything is distorted and disorganized. Don’t know why this is happening but I attached a link below.
4. Anyways i can have a full width page? like for yycnow.com/thingstodo (1234 password) I want this page to be full width.
Visual Composer – http://imgur.com/GrUyexI
Website appearing distorted – http://imgur.com/x5XjNpc
Visual composer completely stopped working – http://imgur.com/dfuGXse
Like the backhand editor button is gone?
1. 3. Please check in Visual Composer settings if this option is enabled: http://screencast.com/t/OeqvCNmGnf Also try to deactivate all plugins except VC, clear all caches and test again.
I’ve checked your site and usually loads fine: http://screencast.com/t/iUaEDuEEJR but sometimes seams that the theme’s css isn’t loaded: http://screencast.com/t/MxA8TA0r I am not sure what’s blocking the the css but you can try by viewing the site a few times in browser only with Visual Composer active, just to make sure that there is no conflict with some plugin.
2. This could be a cache issue so make sure that you’re empty all caches then test again.
4. The theme wasn’t designed to be full width, you will need custom modification to achieve that. However I’ve noticed that on the indicated page you have only single image blocks from VC. You can try the stretch row and content option of VC but I am not sure how will as wasn’t tested with the theme: http://screencast.com/t/pgZmuEkt I’ve made a quick test with this configurations and seams to work fine: http://screencast.com/t/RtPnmDjOZOhttp://screencast.com/t/doEVYIFrlmi http://screencast.com/t/tRlYotyvGsY
Hope this help.
So sometimes the backhand editor wont appear still? Also like you said the css is being blocked. This all started to happen after I updated the theme. Can you please help me fix this
The times visual composser will load, it still bugs out and loads like this – http://imgur.com/ogtncGD
Like I cant even edit the rows and create 1/3 1/4 etc
Please deactivate and delete the VC plugin and reinstall it using this method: https://forum.tagdiv.com/how-to-update-visual-composer-plugin/
Please try it only with visual composer active. Disable ALL other plugins. If the problem is still there afterwards, please send an email at contact@yahoo.com with your login information so we can take a look. Please also include a link to this topic.
