we would like to use TD Composer on a Custom Post Type (CPT). It’s not working but please don’t tell me that it will not work. We will need it for several special pages and will do all the steps needed to activate it.
Thanks in advance
Regards
Hello !
You can edit it by adding a custom single post template to your post pages. Find out more about it here: https://tagdiv.com/customize-articles-with-single-post-templates/
Thank you very much for your answer.
I looked at the manual, but didn’t find a way to get a CPT with the possibility to use the TD Composer. The link to the composer is not displayed.
I added a Cloud Template. How do I assign to my Custom Post Type “Magazines”? I want to separate normal Posts and Custom Post Types.
Regards
Hello !
Unfortunately the CPT and Composer do not work. They will work only on default template.
Please take a look at this documentation regarding Custom post type: https://forum.tagdiv.com/custom-post-type-support/
We are sorry for the inconvenience.
