Create a specific sidebar for post
How is it possible to create a sidebar for some specific posts?
I don’t understand anything to the way your templates works !! (even managed other wordpress website)
You can do this in more ways, you can use a single post template from tagDiv Cloud library, edit it with tagDiv Composer and adjust it after your needs, if you do not want to have the same sidebar for all posts, then you can do the follow thing, use a classic post template and make sidebars using widgets, these can be assigned to posts individual.
Newspaper Theme: How to Import and Assign a Single Post Template on Your WordPress Website -> https://www.youtube.com/watch?v=I1R3j1QYod0 -> https://www.youtube.com/user/tagdiv
Hope this will help you!
