Is it possible to create a series of options or templates within posts?
Essentially, I need a set of posts with a sub nav of: A, B, C and another set of posts with a sub nav of D, E, F.
Does that make sense and if it isn’t possible, how can it be made possible?
If you need custom post type, then please follow our guide from here to know exactly how can you achieve that: https://forum.tagdiv.com/custom-post-type-support/
If it is not what you mean, then please provide me an example or maybe a screenshot with exactly what you need to achieve.
Hope that helps you!
Essentially, I need to create 7 custom secondary nav options that look like this – https://ibb.co/tqvR3S4 for my posts.
I need the option to be able to define which menu is displayed in Posts via the admin. Is this possible??
Website is: https://firstcardev.wpengine.com/
