Hi all,
I’m trying to get Newspaper tagDiv Composer play nicely with our domain mapper plugin.
It seems to be throwing a cross origin whenever it loads up the editor (never stops spinning).
It seems to be throwing when it gets to this part of the code in css-live.php line 396
// Everything must be done onLoad, to be sure that all live css components are in loaded.
jQuery( window ).load(function(){
if ( ‘undefined’ !== typeof window.parent.editorChangeHandler ) {
Not sure what’s going but it seems to be making a call to jquery using the un-mapped url
http://localnetwork.napco.com/our-website/wp-includes/js/jquery/jquery.js:2:26863
Has anyone experienced this before?
It works when I turn off the domain mapper.
Any help would be greatly appreciated.
Please make sure that the theme system status is configured as mentioned in the requirements guide. Please follow the guide carefully
WP_MEMORY_LIMIT try to increase it to a value of double you already have if possible.
Please add this code in the .htaccess , file at the end of the file:
<IfModule mod_substitute.c>
SubstituteMaxLineLength 10M
</IfModule>
Also it can be some conflict between those plugins ( tagdiv Composer and mapper plugin )
Thank you .
