Greetings,
I could not be more happy with this theme/demo. I was able to build out a sophisticated cryto site in ~ 2 days! Big Question and help needed:
The posts that appear in front page columns “Hot Stories”, “Must Read”, “Regulation”, “Mining”, appear to be randomly selected for insertion (looking at the code.) How do you suggest that I can alter the code so that only posts concerning, for instance, “mining” appear in the “Mining” section, etc, etc?
Do you offer custom coding for this demo? If so, what is your process for engagement?
Thanks,
The Crypto Register
The blocks can be set to show the articles that you want/need. Please read this guide: https://forum.tagdiv.com/block-settings-tutorial/
