Hello dear team following thing is causing lay out shift of 0.23 in google page speed index, can you tell me how to fix this:
<article id=”post-5897″ class=”post-5897 post type-post status-publish format-standard has-post-thumbnail…” itemscope=”” itemtype=”https://schema.org/Article” style=”height: auto !important;”>
Hello Calin, thanks for reaching out, on our home page we dont have any ad but there still we get layout shift of 0.16 on desktop and on mobile its 0.38.
This following (given below) error is causing CLS of 0.377 , can you tell what is this about and how to fix this as it is the major reason of failing:
<div class=”td-main-content-wrap td-main-page-wrap td-container-wrap”>
Hi Calin,
Similar problem with a clients website:
Can you please have a look.
https://tinyurl.com/4kye2jk5
Same for all internal post pages as well.
Hi iasgharalikhan,
I tested your website using the lighthouse and on a desktop, this looks good – https://i.imgur.com/6eXmrOu.png indeed on mobile the results are a little lower but also good – https://i.imgur.com/Wj7NC9z.png
What I can suggest is to use a cache plugin and possibly a plugin for css and javascript minification, you can try our guide from here – https://forum.tagdiv.com/how-to-make-the-site-faster/
I hope this will help you!
