on digital-magazin.de I have been using the Newspaper Theme for some years now. Last year I did a complete redesign and use the Tech Pro templates as a basis. Everything is great, but the menu is always loaded last.
That’s why I have the problem that it doesn’t look good but also shows errors in the Google Search Console:
Core Web Vitals – Cumulative Layout Shift (CLS) (https://web.dev/cls/)
What can I do so that the menu is loaded first?
Hi nodi, please make sure that you have disable the “Drop menu items in More” from header main menu using tagDiv Composer -> https://i.imgur.com/eJ1D1gU.png
This should improve the load of menu!
Let me know the results!
Hi, I think I might have the same issue and was interesting reading this solution. I’m trying to apply the same changes to my site, howoever, when I enter my home page tagdiv composer, the menu is not selectable. Any help would be greatly appreciated.
Hi MattiaCallian,
The menu can not be selected from tagDiv Composer only if you are using a standard header an not a cloud header, here is some more details about this -> https://forum.tagdiv.com/header-styles/
Hope this will help you!
