Custom Ad not working
I am using the plugin Adrotate to manage my Ads.
I like to use two Ad boxes on the homepage here (“Lütte Piraten” and “Wikingergolf”:
https://kinderkram-sh.de
In the left Ad box (“Lütte Piraten”) I chose Adspot “custom_ad_2” which I configured in the Newspaper Theme panel Ads section with the code for this Ad from the Adrotate Plugin. This works fine.
But when I try to do this with the other Adspot “Wikingergolf” and choose Adspot “custom_ad_3” it gives me just a blank field.
For now I chose custom ad code here and placed the link from the Adrotate Plugin to make the ad visible at least.
But so I cannot control the statistics from Adrotate.
Why does the right Adbox not work with chosen adspot?
Thank you for help
Bernd
Hello Bernd!
In the cloud templates, you can add the ads when you edit the post with TagDiv Composer in the element called ” Single Post Content ” in the tab ADS. Documentation here: https://forum.tagdiv.com/article-ads/
Or you can use the element called “Ad Box” from TagDiv Composer, and there you need to add the ads: https://forum.tagdiv.com/ads-adsense-overview/
Unfortunately, this plugin is not tested with our theme.
