Custom Field in block meta info
Hi!
Can you help me into changing the code in the child theme?
I want to replace (or add the possibility) the category in meta info by a custom field I have.
Here: https://imgur.com/a/jkDkQ86
The modules can be modified in a child theme if needed. A child theme is provided in the theme package (code folder)
– https://forum.tagdiv.com/whats-included/
There is a guide for it – https://forum.tagdiv.com/the-child-theme-support-tutorial/
Copy the module you want in the child theme (create the same directory path to the file as in the main theme). Opening a module file you can see what it is designed to display, for example module 1
– https://www.screencast.com/t/w8Q3PphLU
So if you copy the module you want in the child theme and add code in it or modify it, it should display the additional information.
It worked.
Here is what I did:
<?php //if ($category_position == 'image') { echo $this->get_category(); }?>
<span class="td-post-category">
<?php if ($category_position == 'image') { echo get_field( 'retranca', $this->post->ID ); }?>
</span>
Trying to do the same in Posts Loop 2.
Any help?
@Mercurial
the module used by the loop 2 element is located inside the cloud library plugin
– https://www.screencast.com/t/AYh78gWrDSY
Plugin files cannot be modified in a child theme, so any modifications to them will be lost after a theme update when all the plugins are updated. Old versions of the plugins cannot be used with a newer theme version.
