I am customizing a template. When I try to customize the sidebar and set a black bg white white text, i don’t get the white text. Thus, nothing can be read. if I change the general settings on the theme panel I may screw up the rest of the site.
Help please.
Why is it so complicated to paste different sidebars. It seems they’re already categorized to appear in the section even when one customizes them.
How can I insert an animated .GIF file in a sidebar and have it run the animation/frames???
Hello Paulo Campos,
Before making/customizing your sidebar, you should read our documentation regarding on this thing, like this -> https://forum.tagdiv.com/sidebars-tutorial/ After you get acquainted with these options you should do at Widgets section and there you have to add every block you want to your sidebar, with drag and drop and create your sidebar. So, if you want to load a GIF, you should use the block Text with the title and add there you desired image GIF format.
